Prepare the Installation
Allocate storage
TrendMiner stores application data and logs in /mnt/data. Ensure that this directory has sufficient free disk space.
Install prerequisites for Ansible
The following actions are needed to install Ansible and be able to run the full installation procedure.
$ yum install centos-release-ansible-29
Check IP address usage
